ProjeQtOr free project management software - Problem for install ProjeQtor 4.2.3 with Postgresql 8.4 - Page 2 - ProjeQtOr
24 Jun 2014 09:25 - 24 Jun 2014 10:15 #7 by Mams
Yes. I had already done, I had no error message.
Last edit: 24 Jun 2014 10:15 by Mams.
24 Jun 2014 10:34 #8 by babynus
But what is the behavior ? Nothing happens ?
1) Check javascript console for any error
2) Check PHP log file for any error
24 Jun 2014 11:24 #9 by Mams
Yes, I confirm nothing happens.
Ok, I will check javascript console and PHP log file error, then i send you errors messages.
Thanks soo much
25 Jun 2014 16:05 #10 by Mams
I have no error message in the log files. I will reinstall Postgresql.
25 Jun 2014 17:03 #11 by babynus
You should have an error somewhere (otherwise configuration would complete)...
... unless you just did not scroll down : it happens on some screen resolutions, that the result message and new button are displayed just below visible part of page.
Otherwise, you must have an error :
either in the browser console
or in the php log
of in the apache log
25 Jun 2014 17:05 #12 by babynus
Reinstall postgres should not de necessary.
It is very rare it is not installed correctly.
But access rights should be reviewed.
Also, PostgreSql requires to have the database created before configuring ProjeQtOr. Unlike MySql, database cannot be created on the run.
