ProjeQtOr free project management software - Outlook meeting, format not recognize - ProjeQtOr
05 Mar 2014 17:22 #1 by jmlussier
Hello, when I create a new meeting, the ICS format received is not compatible with my Outlook client
is there something I can do to resolve this problem, this is the 2007 version of office.
05 Mar 2014 18:38 #2 by babynus
It should be compatible.
Which version of Projector are you using ?
05 Mar 2014 19:06 #3 by jmlussier
the latest 4.2.0
it is working on my tablet I can accept or decline the new calendar entry.
05 Mar 2014 19:11 #4 by jmlussier
it is working when I import the file manually, when I received as e-mail it is not importing
could be security of my outlook let me verify that..
15 Oct 2014 15:53 - 15 Oct 2014 15:54 #5 by JarekD
Have you found the solution?
Got similar problem now with ProjeQtor 4.4.2 and Outlook 2013.
Manual import of .ics does not work either...
Google Calendar imports perfectly.
Last edit: 15 Oct 2014 15:54 by JarekD. Reason: More precise description of the problem
15 Oct 2014 16:45 #6 by babynus
Works fine for me With ProjeQtOr 4.4.2 and Outlook 2010.
On internet you can find similar issues :
answers.NotAllowedScript69d3bef26f48cmicrosoft.com/en-us/office/forum...bb-8052-d4dbd58552b8
community.office365.com/en-us/f/158/t/162728.aspx
support.NotAllowedScript69d3bef26f48coffice.com/en-US/Article/Publish...en-US&rs=en-US&ad=US
Some fixed reinstalling Outlook 2013 (strange)
Notice that ics import in not avaiulable on Outlook webaccess
@JarejD : if you found a fix, please share !
