ProjeQtOr free project management software - Probléme d'affichage des caracteres spéciaux - Page 2 - ProjeQtOr
21 Apr 2014 10:43 #7 by sdf
For instance :
- I type : "Mettre à jour les pages HTML"
- after saving the field becomes : "Mettre à  jour les pages HTML"
- if a save one more time, it becomes : "Mettre à jour les pages HTML"
- ad libitum (latin is also an excellent universal language) : "Mettre à jour les pages HTML"
21 Apr 2014 11:38 #8 by babynus
Do you reproduce on Demo ?
21 Apr 2014 16:12 #9 by sdf
No, all is good on the Démo environment, and the lang.js is also good.
So it's a problem upon my own configuration. How can I modify it after installation ?
21 Apr 2014 16:47 - 21 Apr 2014 16:51 #10 by babynus
1) check PHP configuration :
;exif.encode_unicode = ISO-8859-15          //should be commented
extension=php_mbstring.dll        //mbstring should be enabled
default_charset = utf-8
2) check MySql Configuration
[client]
default-character-set=utf8
[mysql]
[mysqld]
character-set-server = utf8
3) check Apache Configuration
AddDefaultCharset utf-8
Last edit: 21 Apr 2014 16:51 by babynus.
31 May 2014 19:36 #11 by sdf
Après un petit tour chez mon hébergeur, le problème est résolu.
J'en profite pour leur faire de la pub parce qu'ils sont particulièrement sympas et efficaces : shost.ca
