ProjeQtOr free project management software - Configuration at first run - ProjeQtOr
31 Aug 2010 15:24 #1 by lahatch
I have to test projector and see if it could be usefull for our needs.
Then I've installed apache 2.2.16, php 5.2.13 and mysql server 5.1.50.
The apache server and mysql server have been started.
Now I'm on the "configuration page at first run", I filled all the fields and clicked o the "OK" button.
Then... nothing.. I'm always on the same configuration page, no dialog box appears, no error...
An idea?
Thx
31 Aug 2010 17:28 #2 by babynus
You should get a message positionned below the "OK" button.
Maybe you must use scrollbar to see it.
The message is red if it is an error message, or green if data is correctly saved.
In this last case, the message is "Parameters are saved", and a new "Continue" button appears : just click on it to go further.
If this does not help you to solve your problem, can you please :
- indicate what browser your are using, and precise the exact version used.
- indicate on what OS you installed your Apache/PHP/MySQL (windows, linux, ... ?)
- check if any JavaScript error is raised by your browser
- check your php log file to see if any error has been logged
- chech your Apache log file to see if any error has been logged
- check your MySQL log file to see if any error has been logged (you may have to wait for your default MySql timeout delay before having data in your log file)
Then get back to me with data of these files.
Don't hesitate to ask if you need precisions about requested information.
Babynus.
01 Sep 2010 10:06 #3 by lahatch
Bonjour,
j'ai vu que certains post était en français, ce sera plus facile pour moi..
Donc concernant la scrollbar, il n'y en a pas et aucun message n'apparaît sous le bouton "OK".
Browser : firefox 3.5.5
OS : RHEL 5
1) lorsque j'accède à la page de conf (http://localhost/projectorria), j'ai un certain nombre d'avertissement dans la console d'erreurs, ainsi que l'erreur suivante :
dojo.byId("login") is null
http://localhost/projectorria/view/main.php 32
2) je clique le bouton "OK"
Apache : rien dans le fichier error_log, et au niveau du fichier access_log, les lignes suivantes :
127.0.0.1 - - [01/Sep/2010:09:41:46 +0200] "GET /projectorria/view/css/images/buttonHover.png HTTP/1.1" 200 144
127.0.0.1 - - [01/Sep/2010:09:41:57 +0200] "GET /projectorria/view/css/images/buttonActive.png HTTP/1.1" 200 129
127.0.0.1 - - [01/Sep/2010:09:41:57 +0200] "POST /projectorria/tool/configCheck.php?destinationWidth=752.133 HTTP/1.1" 200 -
Php : contenu du fichier projectorria/php.ini :
magic_quotes_gpc = Off
error_log = /var/log/php-scripts.log
display_errors = On
error_reporting = E_ALL
=> aucun fichier /var/log/php-scripts.log n'a été créé
Myql : je ne sais pas où se trouve le fichier de log..
Voilà, bon je ne sais pas si ça peut aider à résoudre mon problème, en tout cas je n'arrive toujours pas à dépasser la page de conf.
01 Sep 2010 11:54 #4 by lahatch
Re bonjour,
bien j'ai résolu mes problèmes, le module mysql était mal installé/configuré.
Donc maintenant j'arrive sur la page de login. Sauf qu'à aucun moment je n'ai créé de compte utilisateur... Il y en a un par défaut ?
01 Sep 2010 13:35 #5 by lahatch
En lisant un peu les autres post c'est bon, j'ai trouvé le login/mdp à la première connexion (admin/admin).
18 Oct 2010 13:54 #6 by Guest
Hi Baybnus,
have same issue, but couldn't read french. Would be fine if your suggested solution would be translated in Englisch. If it helps, can translate in Germany if needed.
Thanks in advance.
Klaus
