ProjeQtOr free project management software - Changed hardware requirement 3.4.4 -> 4.05 - Page 2 - ProjeQtOr
19 Dec 2013 11:03 #7 by luckydigit
Dear Babynus,
I add my question in this topic, because I had the same problem and with your solution, I passed to migrate to v4.0.5 (which seems very interesting in).
But, the migration has been made with one error. However, it seems I can use the projeqtor v4.0.5.
I join the log file to see with you if all is ok with my update of the version or not ? and if I have something to do again.
I thank you in advance for your reply,
Sincerely yours,
19 Dec 2013 16:38 #8 by babynus
No log file is aattached.
Please re-attach it, zipped.
03 Jan 2014 15:50 #9 by luckydigit
Babynus,
Sorry for the delay, I wasn't available. I hope the logfile will be attached.
File Attachment:
File Name: projector_...1219.zip
File Size:2 KB
Sincerely yours;
03 Jan 2014 16:13 #10 by babynus
The error in the log is about insert of new Planning Mode.
INSERT INTO `planningmode` (`id`, `applyTo`, `name`, `code`, `sortOrder`, `idle`, `mandatoryStartDate`, `mandatoryEndDate`) VALUES
(17, 'Activity', 'PlanningModeGROUP', 'GROUP', 150, 0 , 0, 0)
V3.4 only used 16 planning mode, so id 17 should be free.
It seems you added some lines in planningmode table...
Try and remove extra line or change id in the request (from 17 to any free id) and play the query directly on the database.
Without this line you will not benefit of new planning mode 'resources work together'
03 Jan 2014 16:36 #11 by luckydigit
Babynus,
I am not a php user, so I don't know how to modify the code, and normally I didn't do that. But maybe I made a bad manipulation.
But could you tell me in which file I have to modify the code you told me.
Now I understand why I don't have the new planning mode. Moreover, where I could find the explanation of this new mode (It wasn't in the help file I looked at.
I thank you in advance,
Sincerely yours.
03 Jan 2014 17:32 #12 by babynus
Just update directly your database with query :
(18, 'Activity', 'PlanningModeGROUP', 'GROUP', 150, 0 , 0, 0)
You can use any Sql tool : Toad for mySql, PhpMyAdmin or else.
