ProjeQtOr free project management software - Close project - Fermer projet - ProjeQtOr
14 Nov 2013 12:05 - 14 Nov 2013 13:27 #1 by protion
Good morning,
I would like I would know how how make to be able to cross a plan in 'rounded off ' when there remains time over.
Beforehand thank you
Bonjour,
Je voudrais savoir comment faire afin de pouvoir passer un projet en "clos" quand il reste du temps dessus.
Par avance merci
Last edit: 14 Nov 2013 13:27 by protion.
14 Nov 2013 13:20 #2 by babynus
It is not possible to close a projets (nor any item) with left work.
The reason is that is should false every planning, as this left work is somewhat planned and uses some resource availability.
So it is important to remove all left work before closing an item.
You can easily do this throught Activity screen (updating left work on assignments) or throught "Real work allocation".
14 Nov 2013 13:30 #3 by protion
Merci pour cette réponse claire et rapide
Thank you for this clear and rapid response
