ProjeQtOr free project management software - Links between directories and projects - ProjeQtOr
22 Oct 2013 16:53 - 22 Oct 2013 17:14 #1 by sam
- I defined a project PP
- I defined directory structure linked to PP.
When i create an document in project XX, I can select all directories defined for project PP. Is it normal?
Last edit: 22 Oct 2013 17:14 by sam.
22 Oct 2013 19:30 #2 by babynus
Yes, it is designed this way.
The project of directory is only a helper to defined default project for documents in this folder. It's not a blocker.
23 Oct 2013 16:11 #3 by sam
Would it be difficult to filter?
=> uploading only directories with no project links (general) and directories linked to a project when creating a document for the given project?
thanks!
23 Oct 2013 16:14 #4 by babynus
Not difficult to filter, but could be a regression for some users as it would bring a non existing restriction.
