ProjeQtOr free project management software - Technical Specifications - ProjeQtOr
26 Aug 2013 09:04 #1 by LEVA
Hi Babynus,
I'd like to know what kind of server you use to run Project'Or RIA (Demo and Track) ?
And what kind of server you'd recommend ?
I'm talking in term of technical specifications.
Thx for your help.
27 Aug 2013 00:47 #2 by babynus
Replied by babynus on topic Technical Specifications
Server for Track, Demo and a few more is :
HP Proliant DL120
UC : 1 x Intel Xeon E3-1230 4 CPU 3.2GHz, 64 Bits
RAM: 8 Go DDR3 ECC
OS : Ubuntu server V12
Same serveur hosting PHP (Zend Server) and MySql
Performance tests on this server showed correct response time up to 1000 concurent users on this server.
27 Aug 2013 08:41 #3 by LEVA
Replied by LEVA on topic Technical Specifications
Thank you :)
29 Aug 2013 10:26 #4 by caccia
Replied by caccia on topic Technical Specifications
Hi Babynus,
You've made me curious :)
I was actually thinking about finding a way to measure performance on my Projectorria setup, so your last comment made me wonder: do you have some method / tool to measure the response time ?
I must admit I know nothing in that area, and haven't yet started to research, so just curious if you would have some ideas.
29 Aug 2013 19:33 #5 by babynus
The esiest way, to my opinion, is use of JMeter (I did my tests using it).
You open your Jmeter, define a proxy to Jmeter, and then play your tests in your browser : JMeters records the test scenario.
You can then parameter your scenario and play it for several users simultaneously.
You'll find many help about JMeter on the web ;)
30 Aug 2013 18:11 #6 by caccia
Many thanks - I'll look it up :)
