ProjeQtOr free project management software - advices on implementing reserve management solution - Page 3 - ProjeQtOr
28 Aug 2013 19:48 - 28 Aug 2013 19:55 #13 by babynus
I found the fix.
Not easy to find :S
It is due to forcing of the ID (I really never use it on my projects).
In this case, the function called to save is ... $object->insert()...
Import is the only way that calls this function. Any other means use $object->save().
Unluckily, although $object->insert() realizes a save calling SqlElement::saveSqlElement, the save() method of all the objects is not called, so all calculated fields are not updated.
So the fix is : on /model/persistence/SqlElement.php, replace lines 307 and following from
public function save() {
    return $this->saveSqlElement();
  public function insert() { // Specific function to force insert with a defined id - Reserved to Import fonction
    return $this->saveSqlElement(false, false, true);
to
    if (isset($this->_onlyCallSpecificSaveFunction) and $this->_onlyCallSpecificSaveFunction==true) return;
    $this->_onlyCallSpecificSaveFunction=true;
    $this->save(); // To force the update of fields calculated in the save function ...
    $this->_onlyCallSpecificSaveFunction=false;
This fix will be deployed on V3.5.0
Last edit: 28 Aug 2013 19:55 by babynus.
30 Aug 2013 18:11 - 30 Aug 2013 18:12 #14 by leodom
Babynus the genius !
Great thanks for that quick fix !
I will try it now...
Last edit: 30 Aug 2013 18:12 by leodom. Reason: spelling correction
