ProjeQtOr free project management software - modify - ProjeQtOr
modify <?php echo i18n("applicationTitle");?>
13 Aug 2013 16:20 #1 by yankee_doodle
possible to modify page title? can only find reference to the applicationTitle..
regards,
yankeeeeeeeee doodle
13 Aug 2013 23:15 #2 by babynus
What do you mean by "page title" ?
14 Aug 2013 10:49 #3 by yankee_doodle
ref attached screenshot. don't want to change the icon, only the title..
regards,
14 Aug 2013 16:25 - 14 Aug 2013 16:27 #4 by LEVA
You can modify the applicationTitle line in the lang.xls I suppose.
There are numerous balises like this :
<title><?php echo i18n("applicationTitle");?></title>
Last edit: 14 Aug 2013 16:27 by LEVA.
14 Aug 2013 20:11 #5 by babynus
Yes : just change values for code "applicationTitle" in lang.xls and regenerate lang.js files with included macro.
The following user(s) said Thank You: yankee_doodle
18 Aug 2013 13:55 #6 by yankee_doodle
merci b,
modified values for code "applicationTitle" in each lang.js < generating lang.js files macro failed in openoffice calc (microsoft excel is at my office)
regards,
