ProjeQtOr free project management software - object detail display issue - ProjeQtOr
15 Jul 2011 04:08 #1 by Guest
I found four issues in object detail page in Tickets.
1. display issue:
when I want to insert multilines of content into result field and firstly, I enter 'enter' key.
The focus showed in input box delayed and seems cut. Wait for a while, the new line shows.
And I tried to scroll back to the top, the top few filelds may be hided (ex. planning activity, id, project, status..)
depending on the lines of the new lines I insert.
2. extended date:
In previous version V1.5.5, when I choose initial end date, the extended end date will be automatically set to the same as
initial end date. But in V1.6.0, the extended end date won't be automatically set.
3. I accidentically choose the done date field in object detail page and saved (the checkbox keeps unchecked),
then, I found the done date is set and can't be cleared.
4. the combo box of the date/time field seems too big and truncate the day/hour/minute of the content.
Please help to check.
I use firefox 3.6.16 & IE 7 to test.
Thanks a lot.
Best Regards,
Selina
19 Jul 2011 19:43 #2 by babynus
1) registered as issue #362.
(due to new dojo 1.6.1, workaround searched)
2) registered as issue #363
under analysis
3) registered as issue #364
4) could you explain /detail test case : which screen, which field, how to reproduce.
21 Jul 2011 08:18 #3 by Guest
For 4),
it happend in Ticket object detail page:
the year/month/day field of initial due date & extended due date become to display as combo box,
not like V1.5.5 input box display.
So ex.
after I set date to 2011 Jul 20th from the calendar, I only can see like 2011/7 or 2011, the rest of the date data
will be hidden by the combo box arrow.
Best Regards,
Selina
21 Jul 2011 15:07 #4 by babynus
Strange you have the combo arrow, as the widget has been parametered to hide it.
I investigate.
Are you reproducing on any browser or on specific one ?
22 Jul 2011 02:14 #5 by Guest
I just use Firefox 3.6.16 & IE7 to test it.
Both have this symptom.
Best Regards,
Selina
