ProjeQtOr free project management software - Documents directories Problem - ProjeQtOr
09 Jul 2013 09:43 #1 by DjackJack
I think I have detected a problem with the management of documents. If you have document versions in a directory and we decided to change the directory path (in the Documents directories menu), versions of documents are not downloadable. I explored a little more and I could see that the directory document that I modified partially functionned.
Indeed, the new directory was created, but the old directory was not deleted and the files were not copied to the new directory.
09 Jul 2013 11:26 #2 by babynus
Ticket #1131 recorded
09 Jul 2013 13:59 #3 by babynus
I just checked : all is working fine, at least since V3.3.2.
Please check access rights to your directories.
Possibly your documents were not moved because php user does not have rights to.
Tocket #1131 canceled.
09 Jul 2013 16:23 #4 by DjackJack
Ok, but where can I adjust these access rights (for document directories)
09 Jul 2013 16:29 #5 by babynus
Directly on the OS of your server...
09 Jul 2013 17:19 #6 by DjackJack
But users have never had access rights to the server and its functioned
