ProjeQtOr free project management software - Requirements for project overview to display - ProjeQtOr
15 Jun 2013 14:36 - 15 Jun 2013 14:41 #1 by Rexeh
What criteria must be met, in order for the projects dashboard view to render a project?
By this I mean the today view as shown here - manual.projectorria.org/manual.php?page=34&tag=
I know one of these is the logged in using having an affection to the project, but there also must be criteria such as required validated start? or requested start?
Be good if the answer makes it into the manual also to help others :).
Last edit: 15 Jun 2013 14:41 by Rexeh.
15 Jun 2013 20:13 #2 by babynus
Criteria are :
- current user must be affected to the project
- project must not be closed
- project type must not be "Template" or "Administrative"
That's all.
No criteria on dates or else.
15 Jun 2013 20:17 #3 by babynus
Done for V3.4 :P
16 Jun 2013 11:54 - 16 Jun 2013 12:26 #4 by Rexeh
babynus wrote: Criteria are :
That's all.
I can now confirm this, worth noting that it is not instantaneous, the user must logout then log back in.
:cheer:
Last edit: 16 Jun 2013 12:26 by Rexeh.
