ProjeQtOr free project management software - Creation de la base sql - ProjeQtOr
26 May 2013 17:52 #1 by gg01
Creation de la base sql was created by gg01
Bonjour,
J'ai installé Projector chez Hostinger.
Tout semble ok.
Mais lorsque je me log le première fois il n'y a pas de création de la base de donées
voici le fichier files/config/parameter.php
<?php
// Automatically generated parameter file
$paramDbType = 'mysql';
$paramDbHost = 'mysql.hostinger.fr';
$paramDbPort = '3306';
$paramDbUser = 'u396692928_gg';
$paramDbPassword = 'xxxxxxxxx';
$paramDbName = 'u396692928_mt';
$paramDbDisplayName = 'My Own Project\'Or RIA';
$paramDbPrefix = '';
$paramLdap_allow_login = 'false';
$paramLdap_base_dn = 'dc=mydomain,dc=com';
$paramLdap_host = 'localhost';
$paramLdap_port = '389';
$paramLdap_version = '3';
$paramLdap_search_user = 'cn=Manager,dc=mydomain,dc=com';
$paramLdap_search_pass = 'secret';
$paramLdap_user_filter = 'uid=%USERNAME%';
$paramMailSender = '';
$paramMailReplyTo = '';
$paramAdminMail = '';
$paramMailSmtpServer = 'localhost';
$paramMailSmtpPort = '25';
$paramMailSendmailPath = '';
$paramDefaultPassword = 'projector';
$paramPasswordMinLength = '5';
$paramDefaultLocale = 'en';
$paramDefaultTimezone = 'Europe/Paris';
$currency = '€';
$currencyPosition = 'after';
$paramFadeLoadingMode = 'true';
$paramIconSize = '22';
$defaultTheme = 'ProjectOrRia';
$paramAttachementDirectory = '../files/attach/';
$paramAttachementMaxSize = '2097152';
$paramReportTempDirectory = '../files/report/';
$paramMemoryLimitForPDF = '512';
$logFile = '../files/logs/projector_${date}.log';
$logLevel = '2';
Le fichier log
2013-05-26 17:20:40 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'u396692928_mt.parameter' doesn't exist
2013-05-26 17:20:40 ***** ERROR ***** For query : select * from parameter where (idUser is null and idProject is null)
2013-05-26 17:20:40 ***** ERROR ***** Strack trace :
2013-05-26 17:20:40 ***** ERROR ***** #0 Sql->query called at [/home/u396692928/public_html/projectorria/model/persistence/SqlElement.php:1236]
2013-05-26 17:20:40 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/home/u396692928/public_html/projectorria/model/Parameter.php:485]
2013-05-26 17:20:40 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/home/u396692928/public_html/projectorria/view/login.php:24]
2013-05-26 17:20:40 ***** ERROR ***** #3 include called at [/home/u396692928/public_html/projectorria/tool/projector.php:121]
2013-05-26 17:20:40 ***** ERROR ***** #4 require_once called at [/home/u396692928/public_html/projectorria/view/main.php:10]
2013-05-26 17:20:40 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/home/u396692928/public_html/projectorria/view/login.php:121]
2013-05-26 17:20:40 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/home/u396692928/public_html/projectorria/view/login.php:150]
2013-05-26 17:20:40 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/home/u396692928/public_html/projectorria/view/login.php:156]
2013-05-26 17:20:49 ===== TRACE =====
2013-05-26 17:20:49 ===== TRACE ===== =====================================
2013-05-26 17:20:49 ===== TRACE ===== DataBase actual Version =
2013-05-26 17:20:49 ===== TRACE ===== ProjectOR actual Version = V3.3.2
2013-05-26 17:20:49 ***** ERROR ***** ERROR *****
2013-05-26 17:20:49 ***** ERROR ***** on file '/home/u396692928/public_html/projectorria/db/maintenance.php' at line (267)
2013-05-26 17:20:49 ***** ERROR ***** cause = set_time_limit() has been disabled for security reasons
Les données sql chez Hostinger
26 May 2013 20:17 #2 by babynus
Replied by babynus on topic Re: Creation de la base sql
les hébergeurs n'autorisent généralent pas.la création dynamique de bases de données.
Il faut utilser leurs outils et spécifier les infos dans project'or ria
28 May 2013 06:42 #3 by gg01
Replied by gg01 on topic Re: Creation de la base sql
Bonjour et merci pour la réponse.
J'ai importé ma base créer en local sur le serveur. l'import c'est bien passé (structure + table )
Néanmoins j'ai toujours la même erreur. Je n'arrive pas à passer l'étape de
"Mise à jour en cours
Seul un administrateur peut se connecter"
Avez vous une idée pour passer cette étape ?
Merci
En parallele j'ai pris contact avec mon hébergeur. Et j'attend sa réponse.
28 May 2013 21:34 #4 by gg01
Bonjour,
C'est bon j'ai suppriméla ligne 267
//set_time_limit(300);
et ca passe. La base de données est créer tout fonctionne ok
Merci pour votre travail
The following user(s) said Thank You: zatazer
19 Dec 2013 17:55 #5 by zatazer
Replied by zatazer on topic Re: Creation de la base sql
Merci pour l'info, elle m'a débloquée
29 Mar 2014 13:28 #6 by zatazer
Replied by zatazer on topic Creation de la base sql
Arf, en voulant reinstaller sur un site de prod, j'ai eu le même soucis.
Je reposte ici ma solution pour tt le monde est aussi pour m'en rappeler :
Dans projector.php :
- J'ai commenter le contenu de la fonction projeqtor_set_time_limit($timeout) comme suit :
function projeqtor_set_time_limit($timeout) {
if( ini_get('safe_mode') ){
traceLog("WARNING : try to extend time limit to $timeout seconds forbidden by safe_mode. This may lead to unsuccessfull operation.");
} else {
traceLog("MTa_INFO : Fonction désactivée par MTa : ");
//$max = ini_get('max_execution_time');
//if ($max != 0 && $timeout > $max) { // Don't bother if unlimited
// @set_time_limit($timeout);
En suivant les écriture sur le fichier de log, j'ai vu que les tables étaient correctement crées. Le dernier log est : ===== TRACE ===== DATABASE UPDATE COMPLETED TO VERSION V4.2.3
A ce moment la connexion n'est tjrs pas possible ; le sablier tourne et tourne.
J'ai remis le contenu de la fonction comme à l'origine et fermé le fichier.
J'ai cliquer sur le bouton OK de l'interface de connexion, et là j'ai de nouveau accès à projeqtor.
Est ce un bug dans le projet ? Faut il laisser les admin créer un ticket ou le signaler ?
