ProjeQtOr free project management software - Upgrade problem - ProjeQtOr
Upgrade problem
15 May 2013 11:15 #1 by Bujacic
Upgrade problem was created by Bujacic
I made upgrade from v2.6.3 to v3.2.2:
1. I stoped apache2 web srv
2. unziped projectorriav322 to /var/www
3. start apache2
The message occured: SQLSTATE Access denied
4. I changed sql pswd and DbName
"Invalid logon parameters" occured.
After creating new Db (with new name) logon success, but all data (projects, etc) was lost. We are stil in testing phase, so there was no demage, but ...
Is there any possibility to return our testing data?
We are trying to implement project sw, and there are two other candidates: MS Project and .Project (driven by my colleges).
I even start to translate lang.js to croatian (finished 200+ lines).
15 May 2013 11:38 #2 by babynus
Replied by babynus on topic Re: Upgrade problem
This is no real need.
If you unzip to a new folder, you'll get a new setup.
Upograde process is to unzip to overwrite existing one.
With new db name, you get brand new data.
Just retrieve your previous db parameters (in the parameters.php file, located as defined in /tool/parametersLocation.php). The database will be upgraded to new version. (although is should not be necessary, make a backup of your database before, it is always a good advise).
To my opinion, MS-Project is the best ... for planning pirpose only. It is very weak on all other functionalities.
Great !!!
Don't hesitate to send it to me to have it inlcuded in further version !
NB : you'd better work with lang.xls rather than lang.js.
lang.xls includes a macro to automatically generate .js files (for all languages)
