ProjeQtOr free project management software - Problem the activities of a project created by an admin are being assigned to all the resources - ProjeQtOr
18 Apr 2013 19:21 #1 by imenkolsi
Hello again ,
this is time i think that i found an error (or may be something going really wrong in my data ) in projector'ria .
when i create a project from the admin acount. then i create some activities and assign them to a resource
when i try to impute works to this resource i found that all the resource are getting involved in those activities and that project which i found really bizare
( toutes les ressources sont affectées à ce projet )
I deleted the affectation once again and i tryied again to impute to that resource that supposed to be the only one affected to that project and activity but again all resources are affected to that project
for your information the project has "Traning " as a name !
Well my questions are :
1- if an admin create a project , all the resource are immediatly affected to it ?
2- does you have in your code any control on the data for example project that called tranning, all the resource will be affected to it
3- because it seems like a virus to me , did you manage a control if we exceed an average of projects numbers u get that error ?
Thanks I will appreciate any advice ;)
19 Apr 2013 01:08 #2 by babynus
No ;)
No, neither :P
No, again no...
But I think I know what you're facing... :evil:
19 Apr 2013 08:42 #3 by imenkolsi
19 Apr 2013 10:03 #4 by imenkolsi
19 Apr 2013 10:28 #5 by babynus
I guess the issue is about the type of your project.
If you set type as "Administrative" (or any other project type with code "ADM"), all the resources have to possibility to enter real work on any of its tasks without needing to be affected to the project, nor assigned to the activities.
These kind of projects are dedicated to "Administrative" projects, for instance to follow-up vacancies, sickness days, training periods, and so on.
The following user(s) said Thank You: imenkolsi
19 Apr 2013 10:33 #6 by imenkolsi
Yeah that excatly what i'm facing thanks very much for your help ;)
