ProjeQtOr free project management software - Module PDO not available - ProjeQtOr
18 Apr 2013 10:01 #1 by Garden Dwarf
We have installed Project'Or RIA v3.2.2, and the first page about configuration indicates the following:
Module PDO for MYSQL is not available - check your php configuration (php.ini)
The php.ini file has been changed to uncomment the concerned lines, but the problem still persists. Any idea? Thanks in advance!
18 Apr 2013 10:29 #2 by babynus
After changing your php.ini file, you should restart your PHP server (Apache in most cases)
18 Apr 2013 10:33 #3 by Garden Dwarf
Thank you for your reactivity. However this step was done (at least twice) but situation is unchanged.
18 Apr 2013 11:01 #4 by babynus
Which lines did you uncomment in php.ini?
At least you should have :
extension=php_pdo_mysql.dll
(dll for windows)
