ProjeQtOr free project management software - Status of project - ProjeQtOr
Status of project
15 Apr 2013 11:23 #1 by imenkolsi
Status of project was created by imenkolsi
Hi i'm using projector ria v3.0.0 i've changed the name of the status presented by you
and now i get nothing on the status field even when i try to select one of the new status values they won't be selected and it alert me that can not be choosen
will you tell how can i correct that because now all my project are with no status
15 Apr 2013 12:23 #2 by babynus
Replied by babynus on topic Re: Status of project
My first advise will be to migrate to most recent stable version : V3.2.2
or at least to stable version of V3.0 : V3.0.2
Then :
- check for error in the log file
- check for error in the javascript console
- post here any error found
16 Apr 2013 09:11 #3 by climb4fun
Replied by climb4fun on topic Re: Status of project
Hi imenkolsi,
a second hint: Check Controls&Automation - Workflow. This has possibly to be adopted if you invent new/change status.
Klaus
