ProjeQtOr free project management software - Difference date between planning / ressource planning - ProjeQtOr
25 Feb 2013 18:28 #1 by JCDe
There is a difference logic between the display for planning and planning by resource.
In the planning view, the Gantt displays dates validated when there is no dates planned.
While the planning for each resource, if there is no dates planned, nothing is drawn. Why the logic of the planning view is not used in the planning view by resource?
26 Feb 2013 15:02 - 26 Feb 2013 15:03 #2 by babynus
The difference come from different point of view :
=> on resource planning, you see dates correponding to planning for the resource.
=> on planning, you see dates corresponding to the activity.
Let's concider an exemple :
For task1, Res1 is planned from D1 to D2
For task2, Res2 is planned from D3 (D1<D3<D2) to D4 (D2<D4)
D1___D3___D2___D4
On planning you'll see only one bar from D1 to D4
D1_____________D4
On Resource planning you'll see 2 bars, one for Res1 from D1 to D2, one for Res2 from D3 to D4
D1________D2
     D3________D4
Now, on resource assignment, you never define "validated date" : that's why it cannot be displayed at resource level. Only planned dates can be displayed.
Last edit: 26 Feb 2013 15:03 by babynus.
