ProjeQtOr free project management software - How does the Priority field work? - ProjeQtOr
08 Feb 2013 17:10 #1 by IC_PRQA
I have tried to use the Priority field but I cannot see any effect from either raising or lowering it.
How does it work?
09 Feb 2013 16:44 #2 by babynus
Priority on activities will change planning calculation.
Have a look at the manual, it is explained how it is used.
Priority on other items is only informative.
