ProjeQtOr free project management software - How to create a ComboBox - Page 2 - ProjeQtOr
03 Dec 2012 11:48 #7 by babynus
Idea ! :woohoo:
Add "idle" field - int(1) - on table and class.
The following user(s) said Thank You: a.mikael
03 Dec 2012 11:53 #8 by a.mikael
Ok, and i have check log file :
2012-12-03 11:50:32 ***** ERROR ***** Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'idle' in 'where clause'
2012-12-03 11:50:32 ***** ERROR *****    For query : select id as id, name as name from clarety where (idle=0 ) or id= '1' order by clarety.name
2012-12-03 11:50:32 ***** ERROR *****    Strack trace :
2012-12-03 11:50:32 ***** ERROR *****    #0 Sql->query called at [C:\wamp\www\beta_V3.0\model\persistence\SqlList.php:82]
2012-12-03 11:50:32 ***** ERROR *****    #1 SqlList->fetchList called at [C:\wamp\www\beta_V3.0\model\persistence\SqlList.php:34]
2012-12-03 11:50:32 ***** ERROR *****    #2 SqlList->getList called at [C:\wamp\www\beta_V3.0\tool\html.php:49]
2012-12-03 11:50:32 ***** ERROR *****    #3 htmlDrawOptionForReference called at [C:\wamp\www\beta_V3.0\view\objectDetail.php:803]
2012-12-03 11:50:32 ***** ERROR *****    #4 drawTableFromObject called at [C:\wamp\www\beta_V3.0\view\objectDetail.php:2416]
03 Dec 2012 11:57 #9 by babynus
Logged error confirms previous idea :
03 Dec 2012 12:01 #10 by a.mikael
So, i have add idle (DB and class Clarety) and now i see my combo with :
[Yes]
[No]
03 Dec 2012 12:04 #11 by a.mikael
I think there must be a link with displayYes: "Oui" in lang.js
03 Dec 2012 12:10 #12 by babynus
Yes,
Change names "YES" and "NO" to "displayYes" and "displayNo"
