ProjeQtOr free project management software - Error management parents activities. - ProjeQtOr
28 Sep 2012 18:29 #1 by JCDe
When changing a "parent activities" project should automatically change the project activities children?
Otherwise it generates inconsistencies in planning, and export data.
29 Sep 2012 00:57 - 29 Sep 2012 00:57 #2 by babynus
Yes, and it should so much that it does :whistle:
It's already working this way ! ;)
Last edit: 29 Sep 2012 00:57 by babynus.
01 Oct 2012 12:45 #3 by ekolossov
I can confirm it works except the documents: if you change the directory it will not move document into new one
01 Oct 2012 14:31 #4 by babynus
ekolossov wrote: I can confirm it works except the documents: if you change the directory it will not move document into new one
this is an anomaly. Ticket #799 recorded.
Could you precise the test case ?
01 Oct 2012 14:35 #5 by ekolossov
Yes,
1. Create document in directory 1. Upload document. Open document to confirm it works.
2. Change directory by selecting the different one. Try to open document - it will fail. Look in the old directory and you will find uploaded document there. If you move it manually - everything will be Ok and you can open document
01 Oct 2012 15:40 #6 by babynus
Thanks !
