ProjeQtOr free project management software - View and acces on "Real work allocation" - Page 3 - ProjeQtOr
19 Jun 2012 17:54 #13 by babynus
I really don't understand how you got the history you get.
The most strange is the ID change.
There is no way in Project'Or RIA to change an ID...
Did you create your projcts by copy ?
21 Jun 2012 02:47 #14 by climb4fun
Hi Benoit,
may be this helps:
V2.2.3 is base for V2.3. V2.2.3 is stable. Your risk of instability is more or less in all the fields, where V2.3 is modified - see history log.
If you make carefully dumps of you data, you can migrate to 2.3. If there is an error which has an impact to you, then you can step back to 2.2.3 easily. I did this several time while I tested new instable versions.
At least Projectorria has such a high quality, you will not have a showstopper or complete inoperative system.
I hope this helps.
Klaus
21 Jun 2012 09:16 #15 by spiderjn
hi babynus,
i need more investigation on history view, i don't remeber how i create this projetc.
Best regards
