ProjeQtOr free project management software - Read email and create a ticket - ProjeQtOr
22 Jan 2026 16:59 - 23 Jan 2026 06:11 #1 by nicop
Hi
I am still new at this application.
I am trying to read an email address and the created a ticket from the email.
I have confirmed and PHP IMAP ext is installed
I have tried version 12.2.1 as well as 12.4.2 the cron fail messages are different but neither work.
When I run openssl s_client -connect server.name:993 and then do the a login with username and password from the unix console of another server I get the connected
I have tried using {server.name:993}Inbox, {ipaddress:993}Inbox, without the {} ie: server.name:993 but the where I put the Imbox
In version 12.2.1 i get Cannot connect to ticket mailbox #1 | getmail
2026-01-22 17:38:17.845 ***** ERROR ***** [V12.2.1] [CLOSED] IMAP connection broken (server response)
In version 12.4.2 I get on file '/home/projeqtor/public_html/external/PHPImap/webklex/php-imap/src/Connection/Protocols/Protocol.php' at line (208)
What am I doing wrong
Last edit: 23 Jan 2026 06:11 by nicop.
26 Jan 2026 09:06 #2 by maxca
Please ensure that the IMAP format is correct.Example : {imap.gmail.com:993/imap/ssl}INBOX
Please remember to refer to the manual. : test.projeqtor.org/docs/user/html_en/Tic...tml#ticket-fromemail
Have a nice day,
The following user(s) said Thank You: nicop
13 Feb 2026 06:16 #3 by nicop
Had a look at the manual again and the explanation is there but not all that clear. The example given is {imap.gmail.com:143}INBOX.
Perhaps a minor update to the manual would help, but the answer provided did help a lot
Thank you
