ProjeQtOr free project management software - [SOLVED] Issue Configuring SSO SAML2 Between Keycloak and ProjeQtOr - ProjeQtOr
08 Jul 2025 18:02 #1 by bumet
Hello,I'm currently experiencing difficulties configuring SSO authentication via SAML2 between Keycloak and ProjeQtOr.Here’s what I’ve done so far:
  • In ProjeQtOr, I filled in the SSO SAML2 fields under global parameters.
  • In Keycloak, I created a user with the necessary information, client, and attributes (mappers).
  • On my first login attempt, I changed the password, entered the email, last name, and first name, then clicked “Submit.”
However, I received the following error message:
ERROR: An exception occurred on 2025-07-08 at 17:30:01
When I check the logs, I see the following:   I'm unable to identify the root cause of the issue. Could you please help me troubleshoot this and complete the configuration?Thank you in advance for your support.Best regards,
bumet
10 Jul 2025 10:18 #2 by bumet
I added a new mapper on Keycloak     and I get this error message when I try to log in to ProjeQtOr :
10 Jul 2025 16:07 - 10 Jul 2025 16:09 #3 by bumet
Hi everyone, I solved the issue on my own and wanted to share the solution with you:In Keycloak > Clients > Settings, enable "Sign Assertions".
Then, in the ProjeQtOr, projeqtor/sso/projeqtor/settings.php file, set the
'wantAssertionsSigned'
value to true.
Hope this helps !Best regards,
bumet
Last edit: 10 Jul 2025 16:09 by bumet.
18 Jul 2025 15:12 #4 by babynus
Thanks for sharing the solution you found.
Time to create page: 0.067 seconds
