ProjeQtOr free project management software - First Login Error - Page 2 - ProjeQtOr
First Login Error
27 Jun 2025 16:31 #7 by desian.santos
It is a first installation
27 Jun 2025 17:51 #8 by babynus
Replied by babynus on topic Erro no Primeiro Login
It may be an issue for brand new install on V12.2.0 (wich is not tagged stable yet). We are investigating.
Try and deploy V12.1.3, latest stable release.
You'll be able to migrate on V12.2 when it will be more stable.
27 Jun 2025 18:07 #9 by babynus
I just tested first deployment for V12.2.0 : no issue.
I also checked your first screenshort : it is installation of V12.1.3, so issue is not linked to V12.2.0 not stable version
27 Jun 2025 18:13 #10 by babynus
Try this query on projeqtor database
update resource set password='admin', crypto=null, isLdap=0, locked=0 where id=1;
Then you'll be able to connect with
login = admin
password = admin
(you'll have to change the password after first connection)
30 Jun 2025 20:34 - 30 Jun 2025 20:49 #11 by desian.santos
I made the adjustment in the database, but the site returns this message:
"Module IMAP is not available - impossible to configure ProjeQtOr to retreive notes from received emails"
"Upgrade in currently running.
Wait until it ends"
And I still can't log in.
I have already enabled IMAP in the php.ini file.
I am using MYSQL directly on Windows
Last edit: 30 Jun 2025 20:49 by desian.santos.
01 Jul 2025 16:10 #12 by desian.santos
I made the adjustment to the database, but the site returns this message:
"IMAP module not available - unable to configure ProjeQtOr to retrieve notes from received emails".
"The update is in progress.
Please wait until it finishes".
I am using MYSQL directly on Windows.
