ProjeQtOr free project management software - Unable to add a resource to a project - Page 2 - ProjeQtOr
07 Jun 2025 19:02 #7 by babynus
Difficult to analyse error that generates no log.
Possibly, can you open browser console, go to tab network and check access to php files (you can enter a filter).
Then you play use case, and check last call to php : there should be a response tab, please post its content here.
NB : it seems you are on V11.3.2, this is not the latest patch of V11.3, you should at least migrate to V11.3.3.
Also note that support on this forum is restricted to latest stable version, so we highly advise you to migrate to V12.1.2 (or V12.1.3 that is under deployment)
10 Jun 2025 10:56 #8 by Projeqtor_CD49
We plan to update Projeqtor this summer to version 12.
Christophe
17 Jun 2025 12:31 #9 by babynus
Good idea.
V12.1.3 has just been deployed and we are about to deploy V12.2 (that should be tagged stable first half of july)
