ProjeQtOr free project management software - Issue when copy a template project - ProjeQtOr
17 Apr 2025 22:14 #1 by evinatie
Hello,When I copy a template project, I don't automatically find it in my projects. I even get a message telling me that I don't have access rights to this project element.
I can't find the setting that would allow me to avoid this error. Setting the project to manager+ doesn't meet my needs because it shows all the projects.
Could you help me?
I'm using version 11.4.4 in production, but I have the same problem in 12.0.1.
Thank you
Eric
18 Apr 2025 08:19 #2 by maxca
What access does the user in question have to the projects?
In my case, the project leader will only see his projects and will be able to copy the model project.
Have a nice day,
18 Apr 2025 09:27 - 18 Apr 2025 10:32 #3 by evinatie
Thank you for the answer.
But this profile has the good access.
Another question : "the project leader will only see his projects" means the user must be project's idUser or the IdResource ?
Eric
Last edit: 18 Apr 2025 10:32 by evinatie.
18 Apr 2025 15:44 #4 by babynus
After copy, do you remove some allocation ?
NB : if you remove your own allocation to the project, you loose rights to see it.
22 Apr 2025 09:55 - 22 Apr 2025 09:56 #5 by evinatie
So we have to assign all the project managers to the project template, check the assignment box when copying and then clean it up?
Thanks for your answer
Last edit: 22 Apr 2025 09:56 by evinatie.
23 Apr 2025 11:26 #6 by babynus
No.
When you copy a project (template of else) and you have "Manager" rights, an allocation for you on the project is automatically created.
This gives you access to the project.
It you remove this allocation, you loose access to the project you created.
