ProjeQtOr free project management software - Mass delete of acquired rights - HR module - ProjeQtOr
17 Feb 2025 11:31 #1 by mazama
I am using the HR module. For some (yet unidentified reason), an employee got hundreds of thousands of items added as Acquired Rights ("Absence - droits acquis"). I cannot seem to find a way to easily delete all of them. What do you suggest ? Thanks already.
12 Mar 2025 15:38 - 12 Mar 2025 15:38 #2 by Arkhanje
using multi-update in list box tools on the Leave rights earned screen, you can multi-select the list box rows by clicking on them with shift or ctrl key and in the three little dots you have the trash can.
Set a filter on the resource before using the Multi-Update feature. This will make it easier.
Last edit: 12 Mar 2025 15:38 by Arkhanje.
