ProjeQtOr free project management software - Ability to send alerts if no real work is defined - ProjeQtOr
13 Feb 2025 14:43 #1 by fxandrei
So this is somewhat related to my other post about showing the work for a resource.
So every resource ads the work hours on a ticket or activity.
Is there a way to send alerts to users that dont do that ?
The scenario would be this: of users, from a certain team or project, dont have any hours on the previous day, and is not absent, sent notification him and to the project leader (or some other user).
Is there anything related to this kind of behavior ?
13 Feb 2025 14:51 #2 by alainforma
HI
Go to global parameters / Automation / Generation of alerts if real work is not entered ( or partially) / use options as you wish. Easy !
14 Feb 2025 07:47 - 14 Feb 2025 07:47 #3 by fxandrei
Great. Will have a look at it.
But is there a way to define who gets these kind of alerts ?
Last edit: 14 Feb 2025 07:47 by fxandrei.
14 Feb 2025 09:47 #4 by alainforma
Yes, have a look on it, you'll find the answer.
