ProjeQtOr free project management software - [SOLVED] Question about Resetting Values in My Template Project (Project ID 21) - Page 2 - ProjeQtOr
18 Feb 2025 12:17 #7 by chandrashekhar
Thanks,I truly appreciate the time and effort you spent helping me with this. After considering your guidance, I found a solution by creating a copy of each activity in the planning screen to retain records of those with planning dates and duration. I then kept the newly created records without planning dates and duration, removed the old ones, and achieved my intended outcome.Thanks again for your support and the efforts you put into guiding me toward a solution!Best regards
