ProjeQtOr free project management software - [SOLVED] Kanban - quite slow - is it expected ? - Page 2 - ProjeQtOr
12 Dec 2024 07:50 #7 by fxandrei
This is what i get:
=> 19049ms | page='kanbanViewMain.php' | destination='centerDiv' (server:18494ms, client:555ms)
12 Dec 2024 09:09 #8 by babynus
So query is very long on server side (18s).
Just for 100 tiles, it is quite too much.
Check performance of your server.
12 Dec 2024 10:43 #9 by fxandrei
The server is pretty solid. I dont think it has anything to do with the server.
I think it has something to do with the way it check for permissions. It seems to take to much.
Im now sure what i could check and how i should go about things.
12 Dec 2024 12:07 #10 by fxandrei
After further investigation it seems that it has something to do with the mysql server.
Im using a mysql cluster.
I made a backup and clone the projeqtor instance, and configured it to use mysql server installed on the same instance, and it loads the kanban in 1-2 seconds.
I will investigate further.
13 Dec 2024 07:43 #11 by fxandrei
Could you help me out with some hints about what i should actually check in relation with what is exactly happening when accessing kanban ?
I thinking that maybe some queries take longer or something !
18 Dec 2024 10:04 #12 by fxandrei
So it turned out that the main problem was the fact that the main cluster was in a different location and that was the main cause of the slowdown.
I changed the clusterSet so that the main cluster is in the same location as the projeqtor instantance, and now the initial loading of all the tickets takes around 5 seconds, and its acceptable for now.
The following user(s) said Thank You: maxca
