ProjeQtOr free project management software - [SOLVED] How to enable "Products" module - ProjeQtOr
21 Oct 2024 15:33 #1 by TechSage
We want to activate the "Products" module as in the attached screenshot.
Unfortunately our Projeqtor instance does not allow it (we cannot find the parameter). We are up to date with the latest version.
Can you help us to resolve our problem?
Thank you in advance for your help.
21 Oct 2024 15:59 #2 by Plucks
I'm not sure to understand where is your issue. Do you mean "Products" is not available for everyone on your instance ?
21 Oct 2024 16:01 #3 by TechSage
Yes, that's right, the menu does not appear for any of the users.
21 Oct 2024 16:12 #4 by Plucks
Have you checked on the modules management screen (connected as an admin) if the "Configuration" module is enabled ? Don't forget to save if you make any change on this screen.
Have a nice day.
21 Oct 2024 16:27 #5 by TechSage
Thanks, it works, I didn't see that it was hidden in the configuration category.
Thanks for your quick help :)
