ProjeQtOr free project management software - Problem with timesheet - Nothing appears - Page 2 - ProjeQtOr
25 Sep 2024 14:40 #7 by holecekr
I deleted the user parameters and the timesheet report works again when the window is maximized. The "switch to month view" button causes the problem. After clicking this button, the timesheet will stop working when the window is maximized.
25 Sep 2024 15:26 #8 by babynus
Then there must be an error logged on server side.
If not error is logged on projetor log, check for php error log or apache error log
I would gess it is a memory limit issue.
02 Oct 2024 13:43 #9 by holecekr
Thank you for providing support. I didn't find any error in the server log. However, this is web hosting, which can result in the mentioned lack of memory.
09 Oct 2024 08:56 #10 by pipobru
I have some time a probleme (but pearps is not the same), timesheet page is not displayed. After some investigations i think the probleme is when a user change view from weeks to months and on the months view some lines are closed before.
For solve the problem i run directly in the databe a query for change default view from month to weeks for this user, and after all is ok.
Regards.
Bruno
10 Oct 2024 07:25 #11 by holecekr
Can you please tell me which parameter for changing the display in the database you changed? I solved it by deleting all parameters. Changing (deleting) one parameter is definitely more effective.
Thank you.
Radek
10 Oct 2024 08:12 #12 by pipobru
hello,
my query: update public.parameter set parametervalue='week' where parametercode='imputationPeriodType' and parametervalue='month'
for unlook all users
Bruno
The following user(s) said Thank You: holecekr
