ProjeQtOr free project management software - Critical Path and Gantt Chart help - ProjeQtOr
23 Sep 2024 10:51 - 23 Sep 2024 10:55 #1 by cdhamilton
Hello ProjeQtOr Community,
I’m setting up a project in ProjeQtOr and would like to confirm if the critical path is being calculated correctly based on my current setup.
Here’s what I’ve done:
  • Work-Packages: Entered all work-packages with appropriate dependencies (e.g., Finish-to-Start, Start-to-Start).
  • Milestones:
    • ​​​​​​​Project Start: Set as the predecessor for the very first work-package.
    • Project Finish: Set as the successor for several terminal work-packages that have no tasks following them. I’ve attached a screenshot of the Gantt chart with the “Show Critical Path” option enabled.
Questions:
  1. Does the critical path appear to be calculated correctly with this configuration?
  2. Is there anything I might have set up incorrectly that could affect the critical path calculation?
Last edit: 23 Sep 2024 10:55 by cdhamilton.
25 Sep 2024 10:15 #2 by Arkhanje
Did you check the box to recalculate your project taking into account the critical path?
Do you get the same result by doing so?
25 Sep 2024 10:26 #3 by cdhamilton
I do not have that option. My interface looks different. Please see attached screenshots.
25 Sep 2024 10:54 #4 by Arkhanje
ouch
What version are you working on?
28 Sep 2024 09:09 #5 by cdhamilton
Version V10.3.6
Do you think my critical path looks correctly calculated?
30 Sep 2024 09:08 #6 by Arkhanje
It's hard to know without having access to your data since it's a critical chain. Whatever happens, it's better that you do a quick update to the latest stable version.
First, because we only take into account the latest version to help you on the forum and second, since version 10.3 there have been a lot of bug fixes and new features like on the critical path precisely!
