ProjeQtOr free project management software - Read remote SQL database on projeqtor.org - ProjeQtOr
29 Aug 2024 08:28 #1 by martial.duchamp@hmt.ch
Dear,
I run projeqtor on your server (projeqtor.org) and I'd like to read directly the SQL database with my own php code to be able to merge data from projeqtor and from another database. Is it possible? If yes, how can I implement it? Thanks
29 Aug 2024 10:22 #2 by Plucks
No, for security reasons access to the database is not authorised on shared servers.
Access to the database is granted only on the highest level of hosting (>200 users) where the server is dedicated.
Anyway, depending on what you want to do, you may use the API ; if you're interested, please contact us by email.
29 Aug 2024 10:23 #3 by martial.duchamp@hmt.ch
Thank you for your answer. Yes please, could you send be the information about API. Thanks
