ProjeQtOr free project management software - [SOLVED] Rights management: individual expense validation - ProjeQtOr
30 May 2024 17:12 #1 by mazama
Is it possible to finetune the validation of an individual expense ? So far the only option that I have found to prevent an user to be able to set an expense to "validated" on its own is to remove the edit rights, which of course prevents them to correct any mistakes if noticed by the reviewer.
Thanks already
02 Jun 2024 01:01 - 02 Jun 2024 01:01 #2 by babynus
You can play with workflows so that only user with given profile can move expense to Valmidated status
Last edit: 02 Jun 2024 01:01 by babynus.
The following user(s) said Thank You: mazama
04 Jun 2024 12:09 - 04 Jun 2024 12:10 #3 by mazama
Apologies for the silly question, but I struggle to find the screen where workflows are defined and where they can be customized (note: I use the french version).
Last edit: 04 Jun 2024 12:10 by mazama.
04 Jun 2024 15:21 #4 by maxca
That's?
Don't hesitate to consult the online manual
Maxca
04 Jun 2024 15:24 #5 by mazama
I did that same search but no result was shown. I realize only now that the Workflow page was hidden for all roles, even admins.
