ProjeQtOr free project management software - Can a project with its activities and sub-activities be imported via Excel? - ProjeQtOr
29 May 2024 13:47 #1 by bumet
In the "import data" tab, when choosing the type of data to import, one must choose between "project" and "activity", for example. Is there a way to do both at the same time in a single Excel file?
Sincerely
29 May 2024 15:21 #2 by maxca
No, it's not possible. You have to buy a plugin to do what you want to do.
Have a nice day,
Maxca
The following user(s) said Thank You: bumet
30 May 2024 12:30 #3 by jmmbb
No, there is two type of entity for ProjeQtOr.
You need to import Project first then activities (and keep link between Project and Activities either with name (be sure your project's name are unique) or via Id (you need to update Activities files after import Project to be sure to use the right Id.
I do this for data transfert from old project management tool, it need to align all reference (such as type, status, ... in excel files, then impprt project, making link between Project and Activities on activities file then import activities (it work the same for milestone).
But it's the way to reuse data without entering by hand :) !
30 May 2024 12:32 #4 by jmmbb
for me only MS-Project's import plugIn is avalaible. No plugIn to import from EXCEL.
30 May 2024 13:14 #5 by Arkhanje
yes you are right, that is indeed the case, but it does not seem to me that the answer given says the opposite. We just point out that to import different elements at the same time you need the XML format (and XML is not reserved for MSProject...)
Thanks for the rest of the explanations. Otherwise, you also have the details and explanations on the functionalities of ProjeQtOr in the manual, available online and always for the latest stable version.
