ProjeQtOr free project management software - Very slow browsing under Edge since 2 days - ProjeQtOr
21 May 2024 19:26 #1 by dieperie
Not sure the issue, but since two days, extremelly slow browsing using Edge (Version 125.0.2535.51 (Offizielles Build) (64-Bit)). With Firefox, everything seem to be normal
I tested on two different computers, same symptoms.
Log from Edge browser:
=> 330545ms | page='objectDetail.php' | destination='detailDiv' | formName=listForm' (server:5146ms, client:325399ms)
Log from Firwfox browser:
=> 3414ms | page='objectDetail.php' | destination='detailDiv' | formName=listForm' (server:2724ms, client:690ms)
Thank you.
22 May 2024 11:56 #2 by steveostine
Same, since yesterday, with Chrome version 125.0.6422.61 (The last). It's slow.
No problem with Firefox.
Projector version 11.2.2 and version 10.3.4
22 May 2024 12:01 #3 by steveostine
Additional info, the old version of chrome has no problem 124.0.6367.208 .
22 May 2024 19:51 #4 by babynus
If new latency occurs without any change on ProjeQtOr, possibly it is not the source.
Check your browser configuration, possibly some extensions that may have issues with latest browser version.
22 May 2024 20:14 - 22 May 2024 20:31 #5 by dieperie
ProjeQtOr is not to be excluded. Perhaps Javascript incompatibilty. I believe it enters into an endless loop loading data and finally crashes (after few trials) with out of memory.
I don't have extensions installed. Is there a way I can help debugging ?
Last edit: 22 May 2024 20:31 by dieperie.
23 May 2024 09:33 #6 by steveostine
The new version of chrome: 125.0.6422.77 fixes the slowness anomaly for information.
