ProjeQtOr free project management software - Technical Progress - ProjeQtOr
Technical Progress
12 Mar 2024 17:30 #1 by Noemi
Technical Progress was created by Noemi
Is it possible to add the Technical Progress column in the Project general view?
13 Mar 2024 09:23 #2 by Arkhanje
Replied by Arkhanje on topic Technical Progress
Technical progress is information managed by the activity, so you can display it on the activities screen by choosing the corresponding field in the choice of columns.
You can also view this progress on the activity bars of the Gantt view but not on the projects.
