ProjeQtOr free project management software - Problem with timesheet (no access and no error) fore some users - ProjeQtOr
22 Feb 2024 11:50 - 22 Feb 2024 11:52 #1 by pipobru
Good morning,
I just found a workaround to a problem that I can't explain. (Probably a bug).
Some users can no longer access the timesheet page. The hourglass runs indefinitely, there is no error message, neither in the user interface (which ends up remaining white) nor in the logs.
After several tests I managed to make the page work again for these users by proceeding as follows
From the specific access administration page, I switch their profile from unique access to them to access for all their projects
This unblocks the situation for these users.
You must then open the imputations page, switch to a week view, save weeks n-1 and n-2 (without changing anything).
After which it is possible to return the right to “itself” and it works again.
I think this happens when projects or tasks are closed.
Regards.
Bruno.
Last edit: 22 Feb 2024 11:52 by pipobru.
23 Feb 2024 10:19 - 23 Feb 2024 10:20 #2 by Arkhanje
hi
If the project or activity is closed, it is normal to no longer be able to enter allocations on these elements.
Change the state of the element and it will look much better and less complicated than your weird workaround
Last edit: 23 Feb 2024 10:20 by Arkhanje.
23 Feb 2024 12:10 #3 by pipobru
i agree with you, but a page not displayed after a long time without message, that is not normal. Ok if your task is closed, you don't have time remaning and the time sheet is close. normaly without impact, and timesheets are avaible for all other tasks.
26 Mar 2024 13:58 #4 by pipobru
Hello, after more tests, i can affirm this points: All user (admin incluted) can lock the timsheet whith the PB
For unlock a user: with another user (can display timesheet of all users), display timesheet's user with the PB, change the view months or week, save, change week, save. after that the user can (after re conect) use the time sheet page.
