ProjeQtOr free project management software - Simple approval flow setup for tickets - ProjeQtOr
07 Feb 2024 16:05 #1 by CatalystDROID
Can a simple approval flow be setup for tickets?
If possible, what is the best way to go about setting this up?
Is there a tutorial or sample approval setup I can look at?
08 Feb 2024 08:49 #2 by Arkhanje
Each element can be driven by a different workflow.
You choose the states that will be in this workflow and the rights for each of them.
You can refer to the manual on workflow administration or you can register for our next training course  in French on configuring ProjeQtOr !
08 Feb 2024 16:15 #3 by CatalystDROID
I will review the information in the manual and get back with any questions that I may have.
