ProjeQtOr free project management software - How to close Project and throw Notifications - ProjeQtOr
04 Dec 2023 18:00 #1 by Chris33240
Hello all,
As i have see in ProjeQtOr, Project can't be closed when child items is not closed like Questions or Documents for example.
So, is it means that we must closing all child items one by one before cloturing Project or does it exist one command to closed the project and closed their child items recursively.
Also, in case such a commmand exist, does it throw an notification for all items or only for project item.
I take this opportunity to point out that their is no notification by defaut for closing Project in "Event notification" but it is probably related to ProjeQtOr behavior.
And what about restoring Project and all their items, please ?
Thanks you very much for your help.
05 Dec 2023 09:34 - 05 Dec 2023 09:36 #2 by Arkhanje
Good morning,
There is a way to close a project without closing the other elements in Configuration>Acces right> Specific access > Specific update rights > Can force close.
A message will tell you all the elements that this will close. Just click ok and everything will be closed.
To find these closed projects, simply use the “closed” switch button provided for this purpose at the top of each element list.
As for their restoration, you would need to uncheck the “closed” check box in the treatment section of each project and sub-project
Last edit: 05 Dec 2023 09:36 by Arkhanje.
