ProjeQtOr free project management software - Reports don't work anymore on my project - ProjeQtOr
22 Nov 2023 15:59 - 22 Nov 2023 17:07 #1 by brasal
Hi, I used to using reports but for unexpected reasons, they have stopped to work. When I ask one, the gear turns a while, stops, and then nothing appears, on a project it had worked before. I have tested many reports.
What could be the cause please?
Note: The planning can be updated without error.
Last edit: 22 Nov 2023 17:07 by brasal.
23 Nov 2023 09:11 #2 by Arkhanje
Have you tried clearing your browser cache?
Do you have errors in the projector logs? In the browser (console)? The Apache logs ?
Some additional information could help us see things more clearly.
23 Nov 2023 09:48 - 23 Nov 2023 10:01 #3 by brasal
* Emptying browser cache changes nothing
* The search for errors returns everything is alright
* In the projeqtor logs, except expected errors for "Error sending mail" and "Cannot check Version" due to no mail server installed and not opened to web, I have this one:
2023-11-21 16:09:30.442 ***** ERROR ***** [V10.2.3] Exception-[22008] SQLSTATE[22008]: Datetime field overflow: 7 ERREUR: valeur du champ date/time en dehors des limites : « 2023-11-31 »
LINE 1: ...here (1=1 and idle=0 and ( idle=0 and startdate>'2023-11-3...
2023-11-21 16:09:30.442 ***** ERROR ***** [V10.2.3] For query : select id as id, fullName as name from resource where (1=1 and idle=0 and ( idle=0 and startdate>'2023-11-31' )) order by resource.fullName
2023-11-21 16:09:30.442 ***** ERROR ***** [V10.2.3] Strack trace :
2023-11-21 16:09:30.442 ***** ERROR ***** [V10.2.3] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlList.php:339]
2023-11-21 16:09:30.442 ***** ERROR ***** [V10.2.3] #1 SqlList->fetchListWithCrit called at [/var/www/html/projeqtor/model/persistence/SqlList.php:81]
2023-11-21 16:09:30.442 ***** ERROR ***** [V10.2.3] #2 SqlList->getListWithCrit called at [/var/www/html/projeqtor/report/colorPlan.php:164]
Translation : value of date out of limits: « 2023-11-31 ». As date field format is proteted inside every input field, I don't understand how it can happen.
I understand a bad date can block projeqtor operation. But I have no information where is this error.
Last edit: 23 Nov 2023 10:01 by brasal. Reason: additional information
23 Nov 2023 10:08 - 23 Nov 2023 10:35 #4 by brasal
But pdf reports work. Though, there are none consistant results between resource planning and report: the first one shows activities between november 2023 and october 2024 except on august while the report has gaps from february 2024 to july 2024.
Last edit: 23 Nov 2023 10:35 by brasal.
28 Nov 2023 17:18 #5 by babynus
You say many reports fail...
The error you joined concerns one single report.
It's been fixed, and will be deployed in next patch.
Any other report in error ?
30 Nov 2023 17:08 #6 by brasal
I did test most reports and they did fail. But to answer you precisely, I have started testing again all of them, and the result is the ones which failed all work again.
I have no explanation on what did happen. In the time between, I have edited many things: tasks in the task GUI or via a Kanban, mostly status and assignment changes, created another kanban for activities.
