ProjeQtOr free project management software - Template Files xslx Problem - ProjeQtOr
24 Oct 2023 15:25 #1 by SandyIde
Hello,I'm trying to create a template file (in Excel format) for tickets, where I can display the notes of the ticket in Excel. For example, I have already inserted this ([object.ticket.noteText]) but nothing works. I hope that you have a solution.Best regards
26 Oct 2023 09:26 #2 by babynus
Replied by babynus on topic Template Files xslx Problem
Code is just note.noteText
26 Oct 2023 10:40 #3 by SandyIde
unfortunately this does not work, all lines remain blank even though there are texts in the notes, what other possibility is there? What about the checklists, are they downloadable in an Excel format?
26 Oct 2023 10:47 #4 by SandyIde
My file
26 Oct 2023 11:03 #5 by babynus
It seems you try and define a Template for a List of Tickets.
Fields available are much more restricted, as you cannot have lists of lists.
Check available fields is the Template Report definition.
Notes are not available for List reports, they are for detail reports.
