ProjeQtOr free project management software - How does the workflow setting work in 'Types de projets' ? - ProjeQtOr
14 Oct 2023 13:42 - 14 Oct 2023 13:43 #1 by Chris33240
Hello all,
We have already Workflow settings in severals settings like 'Types d'activitées', 'Types de documents'...etc and all of these settings are hierarchically attached to the Project.
I understand that we can choose different workflows on certain parts of the project but what is the function of this settings placed at level project ?
On which part of the project does this setting have an effect excately ?
Thanks you.
Last edit: 14 Oct 2023 13:43 by Chris33240.
19 Oct 2023 19:55 #2 by babynus
Workflow set on Activities Type defined rules to change status on Activities of this type => Easy.
Workflow set on Tickets Type defined rules to change status on Tickets of this type => Still Easy.
Workflow set on Projects Type defined rules to change status on Projects of this type => I mean only the Project objects, not all items defined under the project.
The following user(s) said Thank You: Chris33240
