ProjeQtOr free project management software - [SOLVED] visualization of projects and sub-projects - ProjeQtOr
13 Sep 2023 09:17 #1 by pdecloedt
a team member is assigned to a sub-project, but not to the “parent” project. Is it normal that he does not see the project for which he is assigned?
to avoid "polluting" it, it is not desirable for it to be assigned to "parent" projects
13 Sep 2023 09:25 #2 by alainforma
HELLO,
Yes he is not allocated automaticaly on parent project. you have to do it . On the other way from parent to sub project is automaticaly.
BYE
13 Sep 2023 09:58 - 13 Sep 2023 09:58 #3 by pdecloedt
Sorry, Hello...
It's not possible to just see the sub project, without the parent project ?
Last edit: 13 Sep 2023 09:58 by pdecloedt.
13 Sep 2023 10:03 #4 by alainforma
it should be like that !!! it is weird.
15 Sep 2023 09:10 #5 by babynus
The behavior is like expected.
If you have project P1, with sub-project P1.1, you can allocate user/resource to P1.1 only.
Then user sees items of P1.1 only, as if P1 does not exist.
Pleas post screenshots of your settings (project structure, allocation)
The following user(s) said Thank You: pdecloedt
