ProjeQtOr free project management software - Statistics web - ProjeQtOr
Statistics web
02 Aug 2023 15:27 - 16 Aug 2023 09:34 #1 by sharky
Is there a field in the settings to put a personal code?
I'm looking to put my MATOMO code for solution usage statistics.
Maybe there is already a solution and I'm not looking into the same idea.
Thank you
Last edit: 16 Aug 2023 09:34 by sharky.
14 Aug 2023 18:03 #2 by babynus
Replied by babynus on topic Statistics web
No, there is not.
You'll have to change the core code.
14 Aug 2023 18:21 #3 by sharky
Replied by sharky on topic Statistics web
Thank you.
Where is the best way ?
14 Aug 2023 18:33 #4 by babynus
If you want to get only 1 data per connection, change view/main.php
If you want to get data on each request, change tool/projeqtor.php
The following user(s) said Thank You: sharky
11 Oct 2023 20:15 #5 by sharky
I put the motamo code just before the </head> tag in the view/main.php file
It worked until 19 September, since an update, although I put the code back each time, I no longer have any stats.
Should I change the location of my code?
