ProjeQtOr free project management software - [SOLVED] Backup/Restore of the System and DB - ProjeQtOr
24 Jul 2023 19:37 #1 by CatalystDROID
Is there an option to perform a system and db backup and restore?
What is the recommended process?
25 Jul 2023 09:29 #2 by Plucks
25 Jul 2023 15:03 #3 by CatalystDROID
Thank you for the quick response and feedback. I will check it out and get back to you should I have any further questions.
Thanks again.
25 Jul 2023 15:10 #4 by CatalystDROID
Could I trigger or schedule a backup using phpMyAdmin using cron in Projeqtor?
26 Jul 2023 09:03 #5 by babynus
Absolutely not.
Using Cron in Projeqtor to execute backup is exactly what our DB Backup plugin does ;)
28 Jul 2023 15:11 #6 by CatalystDROID
Understood. Do we have the ability to develop our own plugins?
