ProjeQtOr free project management software - Link between product and component - ProjeQtOr
27 Jun 2023 16:13 #1 by jmmbb
i got several components and version and want to link with products.
When i come from PRODUCT, using "+" to add a component to product, i can't see any of them. I only can create a new component.
When i come from COMPONENT, i can set PRODUTC USED BY THIS COMPONENT and it works fine.
Any help ?
29 Jun 2023 10:32 #2 by Arkhanje
Hello !
We do not reproduce.
On which version ? What profile are you using? Did you change anything in the permissions on the components? products ? The components are not closed?
Do you have any errors in the ProjeQtOr logs? of the Browser?
29 Jun 2023 12:13 - 29 Jun 2023 12:23 #3 by jmmbb
no error in log or browser.
When opening VERSION DE COMPOSANT, the "+" option is not visible on "Structure" or "Composition".
I'm using Admin account, rights over COMPONENTS, COMPONENTS VERSION, PRODUCTS, PRODUCTS VERSION are ok (Manager).
In COMPONENTS, no "+" visible in "COIMPONENTS VERSION"
Last edit: 29 Jun 2023 12:23 by jmmbb. Reason: Complement
04 Jul 2023 09:52 - 04 Jul 2023 09:53 #4 by babynus
On component, there is no + to add a version as it would require to "create" a version.
Link is done when you create a component version, you select the component.
(same thing for product)
The + missing on Structure or Composition is not normal.
It should be present to add a link to an existing item.
I checked the code (in V10.4.1) the only requirement to see the + is to be able to update the component.
[edit] on older version there was an extra constraint that may lead to incorrect display. Be sure to use latest version.
Last edit: 04 Jul 2023 09:53 by babynus.
